Enables or disables the NOS image integrity check feature.
| integrity-check | Specifies configuring integrity check. |
| image | Specifies checking the loaded NOS image. |
| on | Enables image integrity check feature. You are informed if the integrity check fails. |
| off | Disables image integrity check feature (default). |
By default, ExtremeXOS image integrity check is disabled.
If the image integrity check is enabled, during bootup, the system checks the integrity of the NOS image, and notifies you if it has been compromised or not (an error message is logged).
To view the status and configuration of the image integrity check, use the show switch management command.
The following example enables the NOS image integrity check:
# configure switch integrity-check image on
This command was first available in ExtremeXOS 31.1.
